03-09-2022 02:24 AM
I have a Nest connected to a system boiler and hot water cylinder. The settings in the Pro Setup reflect this and I believe have always reflected this since it's been set up. Over the past few months, I've noticed a few things when the hot water schedule turns on:
I'm on software version 5.9.5-2.
I've tried restarting the Nest, enabling/disabling the hot water schedule, and deleting all the hot water schedules and then adding them back in. But no luck so far.
Any help you can give to clarify point 1 and even point 2 would be greatly appreciated.
ss
03-10-2022 02:30 AM
Hi there @ss_tim,
Thanks for reaching out. You can check on the thermostat's settings > Equipment > Continue > Pro Setup > Hot water > On/Off. Let me know what you see in htere please.
03-12-2022 06:30 AM
Hi, I wanted to check in. Do you need any further assistance? If so, make sure to let me know.
03-14-2022 10:09 AM
