02-20-2022 08:28 AM
Current thermostat has single solid wires on: P, O, G, and R terminals.
Actual wire colors are: yellow, white, green, and red.
02-20-2022 08:31 AM
Sorry, I was asking if my current system would be compatible with a Nest thermostat?
02-26-2022 01:59 PM
Hey RobH,
Thanks for reaching out and we're sorry for the delay.
I'd like to verify the P wire on your system. Could you take a photo of your current wiring from your old thermostat and a photo of your main board (HVAC unit)?
I hope to hear from you soon.
Ryan
03-01-2022 02:43 PM
Hey RobH,
I just wanted to follow up and see if you're still in need of help? Please let me know, as I would be happy to answer any questions you may have.
Ryan
03-03-2022 06:20 PM - edited 03-03-2022 06:28 PM
I have a similar question - I have a Climate Master HVAC system (actually two of them in the condo) which distribute heat via the building's hot water system. Connecting the Nest has been a challenge but have made progress, got the system to produce heat but while the hot-water solenoid activates properly on schedule and (under geothermal configuration) the fan does not initiate, requiring manual activation. This setup produces heat but it is not ideal since the fan does not activate with the solenoid. I've attached pics of the original thermostat wiring block, and schematics and the Nest wiring block. Hope you can help and thanks in advance.
On more note: the original thermostat was right beside the HVAC unit (not a great idea) and I had it moved to a more appropriate location meaning a new run of wiring was added on, with the HVAC Brown going to White to the thermostat block. Additionally the HVAC unit has Orange going to Blue wire, and a Gray going to Green wire. The rest, Red and Yellow are straight through,
07-11-2022 09:47 AM
I'd like to jump in here and check if you were able to get your Nest Thermostat connected to your system. Let us know if you have any questions by replying to this thread.
Ryan
