02-20-2022 06:57 AM
I have a Honeywell CT30A1005 thermostat that controls the heater and a cooler controller model 7619A that controls the cooling system. Is there a way to wire them into a Nest Learning Thermostat?
02-26-2022 02:02 PM
Hey Paul22,
Thanks for reaching out and sorry for the delay.
To further assist you on your inquiry, you may take a photo of your current wiring (showing the wire label) so that we could tell if it is compatible with Nest Thermostat.
Also, let us know if your HVAC unit is a 24V unit.
Ryan
03-01-2022 02:44 PM
Hey Paul22,
I just wanted to follow up and see if you're still in need of help? Please let me know, as I would be happy to answer any questions you may have.
Ryan
07-11-2022 09:45 AM
Hope this helps!
Kind regards,
Ryan
