Nest overheating, doesn't connect to wifi, shuts down
Patty00
I have a nest learning thermostat. It is fairly new (bought June 2021).  The unit suddenly started shutting down, disconnecting to wifi, and overheating.  I've tried taking the unit off and putting it back on.  It would work for a minute, with an extremely high temperature reading (e.g. 103 and higher), then overheat, and shut off.  Once, the message said the battery power was too low to connect to wifi.  Anybody else with a similar issue?
0 REPLIES 0
