Nest power adapter
Benzo
Do I need a power adapter for each individual Nest thermostat? I have 3 independent zones, LP base board heat (Forced HW) the wiring in my current setup is red wire to R and white wire to W, there is also a green wire that is not connected at all. Any help would be great!!
Thanks
Hello Benzo,
Thank you for taking the time in letting us know about your inquiry. I'd love to help.
In most cases, Google Nest thermostats can charge their built-in battery using your heating or cooling wire. But there are situations where you might need to connect the Nest Power Connector, and this will be per device to consistently deliver power to your thermostats.
I'd suggest checking your zoning board to see if there's a C wire available so you don't need to install a Nest Power Connector. Here are some references to help you install your Nest Power Connector on your HVAC system.
Please let us know if you have more questions in mind.
We appreciate your help here, @Markjosephp.
@Benzo, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Mel
