Nest power connector
Matthew_sr85
Hello I have a Utica boiler system with a Honeywell control board I believe this is the model number of it Utica-Dunkirk 240009241 CONTROL BOARD when I went to install the nest thermostat they said I needed the nest power connector but I can’t figure out how to wire it
zoeuvre
Hi Matthew_sr85,
Yikes! Let me take a look at this for you.
Are you located in North America or Europe? What type of Nest Thermostat do you have? What is the exact code that your thermostat or the app shows? And could you send us a photo of your previous thermostat wiring configuration and a photo of how are the wires connected to your thermostat?
Also, you can install the power connector yourself, or call a pro. For a brief video of the installation process, go to How to install the Nest Power Connector. You may also check on this Nest Power Connector article to learn more.
Keep us posted.
