Nest remote temperature sensor
MisterMo
How do I set/change temperature setting of a nest temperature sensor using android app?
David_K
Nest Temperature Sensor wirelessly connects to your thermostat. After you connect your temperature sensor to your thermostat with the Nest app, you can set a schedule for it. While the sensor is scheduled to be active, your thermostat will use the sensor’s temperature instead of its own internal temperature sensors.
Nest Temperature Sensor - Google Nest Help
2 REPLIES 2
David_K
MisterMo
Thanks David
