04-28-2024 04:29 PM
Nest Gen 1 running a heat pump.
System works properly with old thermostat.
Wiring transferred from old thermostat in same wire positions.
Cooling turns on air handler and compressor and cools the home.
Heating turn on the air handler but NOT the compressor. Air is room temperature.
No wiring error codes.
Settings-Thermostat-Wiring: Y = Heat/Cool, G = Fan, C = 24V Common, R = Power, W = Empty, O/B = Heat Pump
04-28-2024 04:31 PM
Standard Nest, not Gen 1 learning.
05-01-2024 10:27 AM
Hi jlehm,
Sorry to hear about this situation with your Heating, No worries, help is here! Based on the wiring information you provided, it seems you don't have a W-WIRE which controls heating. Let's try changing the O/B WIRE settings:
If the troubleshooting steps above don't solve your issue, please get a local professional to install a W-Wire because that might be the reason why is not blowing hot air.
Axel.
05-01-2024 11:11 AM
I now have additional information.
If fan is selected from the thermostat to only circulate air in the home - no heat or cooling - heating is activated.
If cooling is selected, the compressor will come on and cool the home. Once the target temperature is reached, heat turns on.
05-03-2024 03:03 PM
Hi jlehm,
Sorry to hear about your cooling still not working. No worries! Here are some additional troubleshooting steps you can try in this article: Troubleshoot strange heating or cooling behavior.
Please take a look and let me know how that works.
Axel.
05-07-2024 05:55 AM
Thanks Axel.
Because the thermostat identifies the connected wires in this way
Can I switch the wires in G and C and test again without causing damage?
On the old thermostat, G is a green wire which should be 24V Common and C is not connected.
I'm not sure why Nest identifies G as fan and C as 24V Common.
05-07-2024 01:34 PM
Hi jlehm,
Thanks for your reply! To help me get a better picture of what's happening, do you mind sharing a photo of your wiring? Also, I have a few questions:
Additionally, please don't swap those wires, that might cause damage to your system. C-WIRE only should be connected in the C-PORT in the Nest Thermostat.
Axel.
05-08-2024 09:33 PM
Single heat pump. Heat exchanger outside, air handler in attic.
Existing thermostat with wiring that operates the heating and cooling correctly.
Nest thermostat we are trying to install.
Wiring that gives the behavior documented above in the thread.
Wiring in the attic by the air handler where dissimilar colors are connected.
Because the C wire was not connected in the existing thermostat, I don't have confirmation how it connects to the unit. The attic wiring shows dark blue C wire connected to black. Nest identifies this connected wire as 24V common and green as Fan. I would expect green to be 24V common as it is on the existing thermostat.
05-10-2024 03:10 PM
Hi jlehm,
Thanks for the reply! Checking the photo of your previous and current wiring. It seems you have the next wires: R, W, Y, and G. I'm using the letter tags for the Conventional system (in your old thermostat). Please try the next troubleshooting steps:
Keep me posted.
Axel.
