08-08-2023 10:03 AM
08-24-2023 09:10 AM
Hi forky,
Thanks for reaching out. I'm sorry for the delay. If your system’s first stage of heating or cooling won’t reach your desired temperature in a reasonable amount of time, your Nest thermostat will turn on additional stages of heating or cooling to ensure that you’re kept comfortable.
Note: using lower stages of heating or cooling is more efficient because the system doesn’t need to turn on and off as often to maintain a constant temperature. Higher stages also use more energy, so running lower stages for longer to reach your desired temperature can save energy.
You can prioritize your second stage cooling by going to your thermostat Quick View menu > Settings > Equipment.
