10-21-2022 11:54 AM - edited 10-21-2022 11:55 AM
Our thermostat at work is in a utility closet, so I have a sensor in the front office where the people are. It is always cooler in the closet as the sun beats in the office windows in the afternoon.
The Nest is configured to use the Senor from 7am to 9 pm (wouldn't it be nice to be able to set our own hours instead of being forced to use the 4 time block they decide are all we need??!).
Well about four times in this past week it has suddenly decided to use the Thermostat in the cooler location as the active measuring device - if it is cooler than the set-point the heat kicks on - even if we are already roasting up front.
See the screen-shot below. The Thermostat in the closet is at 21°C, the sensor is at 23.5°C and the heating is set to 22°C. So the heating should NOT be on. But as you can see, it thinks the temperature is 21°C and so the heating switches on.
The sensor is just fine (I put brand new batteries in it) and it can see it just fine (it is accurately showing the temp in the front as 23.5°), and I can even see the sensor reading climb as the furnace slowly roasts us alive.
I contacted Nest and they had no clue, and were not the slightest bit helpful.
So why the heck is it switching to using the Thermostat as the sensing device when the black dot to indicate my selection is clearly present next to the senor?
10-25-2022 03:12 PM
Hi SDCE,
Thanks for posting ― let's get this sorted out.
Give these steps a whirl:
Keep us posted.
Mel
10-28-2022 04:27 PM
Hey SDCE,
Edward
10-31-2022 11:13 AM
Mel
