10-12-2024 07:53 AM
Error message says no power to unit. I removed thermometer, charged it and it works for a while, then errors out again
10-13-2024 12:59 PM
I have the exact same problem. Can new batteries be installed? Can I get a replacement Nest? Why doesn't the battery stay charged? Charging via the USB keeps it going for about 1 day then the Nest dies again.
10-15-2024 07:29 PM
Thanks for reaching out to the Community. I'm sorry to hear that your Nest Thermostat is having power/battery issues. But no need to worry, help's here!
Before we get started with further troubleshooting, let me ask you some important questions:
Here are some basic steps you can try to troubleshoot the issue in the meantime:
In case it helps, you can also check the following articles to review the Troubleshoot a "No power" alert on a Nest thermostat (E298, E448 or M20 help code) or to Troubleshoot when your thermostat won’t turn on.
Please keep me posted.
Mario
