09-30-2021 04:11 AM - edited 09-30-2021 04:21 AM
On checking heat link with multi meter, 230v power into unit ok but no 12v supply from unit to thermostat. No green light illuminated on unit. Reset tried but to no avail consistent with unit failure.
How can we get a replacement heat link?
The unit is still within 2 year warranty.
10-29-2021 04:36 AM
Hello @KenB,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones are present in the setup?
Cristian
11-01-2021 04:40 AM
Hello again. Just checking in. How's it going with your Heat Link?
