2 weeks ago
I installed a new nest thermostat and it blows out cold when it says heating. I have a Goodman furnace, no heat pump and have reset and rewired a few times with no success. No error codes appear.
2 weeks ago
Just return nest
I have the same nightmare problem now
so upset
2 weeks ago
Yeah I just chatted with someone fornl almost about hour. Confirmed my system is compatible then they started repeatedly asking the same questions they already asked over and over
2 weeks ago
Thanks for reaching out. I'm sorry if you have to go through this.
It's most likely a wiring and system configuration issue, the reason why it's blowing cold air when calling for heat. I'd love to know more about this. Could you please send the photo of your Nest Thermostat wiring and your case number? Also, you can check out this article for more information.
a week ago
Thursday - last edited Thursday
Hi J_weazy19,
