06-12-2023 05:02 PM
We installed a new 2-stage furnace as well as an air conditioning unit. When we set the Nest thermostat to "cool", it starts out working fine and sending cooling air through the vents. However, after about an hour, it starts to send warm air through the system. It won't stay on cool. What's wrong???
06-12-2023 07:03 PM
Post a picture of the thermostat base showing its wiring.
What is the manufacture and model number?
06-13-2023
09:40 AM
- last edited on
06-17-2023
02:15 PM
by
We have replaced the Nest with another thermostat while we try to figure out why the Nest was not working, so I cannot show its wiring. This is a:
Nest Pro Model Display 3.6
Serial No: ******
Device ID: ******
Thanks for any advice you could give us!
06-17-2023 02:19 PM
Hello everyone,
Thanks for looking into this, @Patrick_Caezza.
@dsfnsf, I appreciate you sharing your thermostat details, but for the safety of our community members, this post was edited to remove personally identifiable information.
With this, it appears that you have the Nest Learning Thermostat 3rd generation. To confirm, is this a new installation? Also, it's best for us to look at how it was being installed with the thermostat's wiring diagram. Please share with us a picture of your old thermostat instead so we can determine how it should be wired for the Nest Thermostat.
06-20-2023 02:42 PM
Hi dsfnsf,
06-20-2023 05:26 PM
Thanks for checking in, Mark. I think we're OK right now. We 'rebooted' the thermostat....went back to original settings and then reconnected again. It looks like that did the trick. If we have further problems, we'll be back in touch. I appreciate the offers to help!
06-21-2023 09:48 AM
@dsfnsf, I'm happy to hear that everything has been sorted out. Since we can now consider this one complete, I will be locking this in 24 hours if we don't hear back from you again. Feel free to start a new thread, and we'll be happy to help.
Thanks for all your help here, @Patrick_Caezza and Mark.
All the best,
