09-26-2022 08:36 PM
How do I change the new nest thermostat fan speed setting on google home?
the heating opion has the fan running at max speed and is really loud. Old thermostat had it on low speed.
10-01-2022 10:35 AM
Hi Thomasf77,
Thanks for reaching out. Changing the fan speed is only available for systems with multi-speed fan controls over the thermostat wires. This affects the fan speed when your system is actively heating and cooling. You’ll have separate options to set the fan speed each time you manually turn on your fan or if you set a fan schedule.
To change the fan speed, please follow the steps below:
Press your thermostat ring to open the Quick View menu.
Choose Done to set your system’s fan speed.
Edward
10-05-2022 09:20 AM
Hi Thomasf77,
Edward
10-06-2022 09:37 AM
Hi Thomasf77,
Edward
10-06-2022 09:49 AM
I saw someone do it on the Nest Thermostat. Must be possible
10-07-2022 08:46 AM
Hi Thomasf77,
Thanks for the response. What type of Nest Thermostat do you have? You can click on this link for reference.
Edward
10-10-2022 10:00 AM
Princess
10-11-2022 12:06 PM
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Nest Thermostat and we'd be glad to assist you further.
Princess
10-11-2022 12:49 PM
Please don’t close. It is not resolved
10-11-2022 12:50 PM
Please do not close it is not resolved
10-14-2022 03:19 PM
Hi Thomasf77,
Thanks for the response. Could you tell us what type of Nest Thermostat you have? Also, how is it wired?
Edward
10-18-2022 10:35 AM
Hey Thomasf77,
Edward
10-19-2022 10:38 AM
Hi Thomasf77,
Edward
