01-17-2022 07:31 AM
I have a nest thermostat that has been in place for at least 6 yrs. Not changed a thing. The heat (forced heat furnace off of gas) was working yesterday....today, I look at the screen, it shows orange, shows the setting @65 and the internal room temp of 61...if I were to just look at the thermostat I'd think everything was working fine. Standing under the vents, i feel no air coming out at all.
I've tried resetting the thermostat...turning it off, letting it sit for 20 min, then turning heat back on, etc and still no dice.
Thoughts?
01-21-2022 06:27 PM
I’m having the same issue did you fix yours?
01-22-2022 04:53 AM
Turns out the pressure switch on the furnace was bad
