Nest thermostat heating and cooling at same time
DOD
Replaced regular heat/cool thermostat with a Nest. Seemed fine until next month utility bill came in at $670 instead of $150. Apparently the heat strip had voltage on it at the same time as the a/c was running. No error message, no notification, wiring correct. Not a very good experience for a state of the art device. Any ideas?
6 REPLIES 6
Hi DOD,
I know it has been a while, but I wanted to ensure that everything was covered here.
I'm sorry for the experience and to hear that your bill went up due to your system running at the same time. This might be a power-related or setup issue that could cause this. Could you please share with us your thermostat's wiring? Also, a screenshot of your energy history would help us identify the changes.
I wanted to see if you still needed help. I did find a helpful article with some troubleshooting steps if you're experiencing odd HVAC behavior. Please let us know if you have any other questions or concerns.
Read the article, no help. Straight cool system. Will send usage later.Thermo wiring.jpg
Hi nighthawking,
Thanks for posting your old thermostat's wiring setup on this thread. Could you please tell me more about what happened? Are you having an issues with the power, wiring configuraiton, or setup? Let us know so we can assist you right away.
Hello everyone,
I don't want to be a nudge, but I'd like to check if you were all able to get your thermostat working. Feel free to reach back if you still need help.
I'm checking in to make sure that you've seen my response. Please let us know if you have any additional questions or concerns before we close this thread in 24 hours.
