Nest thermostat keeps turning heating and water on by itself!
Dorsetto
I keep finding my Nest has turned on the heating at full heat! It’s doing the same with water.
Everything is switched to off and nothing is set in the schedule, but every now and then I remote check in the app and find everything on and burning energy.
Is this likely to be as fault and a replacement is needed?
15 REPLIES 15
Frustratedddd
Have you looked at the Bacteria Prevention setting, that might be the issue?
I don’t seem to have that setting.
(in iOS Nest app - maybe look via webpage?)
I didn't say in the app, have a look in the settings of the display.
Settings - Equipment
Hello folks,
Thanks for looking into this, @Frustratedddd.
@Dorsetto, to confirm, could you please tell us the Nest Thermostat model you have and from what country you are posting? Also, I did find an article that might help.
Hey Dorsetto,
Dorsetto
I’ve switched off the bacteria prevention setting. We’ll see if that helps
Hi Dorsetto,
Wonderful! Thanks for the update. Please keep us posted on how it goes, as we would be glad to know what the result will be.
Hello there,
Checking back in—how's it going? Were there any changes? Did turning off the Bacteria Prevention help?
Still having problems.
just checked via app and for some reason heating is set to full and water is on as well.
could it be a faulty device?
Hi Dorsetto,
I appreciate that you kept us informed. What Nest Thermostat model do you own, and where are you posting from? This is to see which settings we need to check.
Hello there,
Its the Nest Learning Thermostat 3rd Generation.
Base:
Model Backplate-6.5
Software version 2.3.23 / 3.1
Dorsetto
t's still random switching on both heating and water to full heat.
Within the past 4 weeks since you asked the question about your thermostat, have you factory reset yet?
Hey everyone,
Thanks for the help here, @Frustratedddd.
@Dorsetto, I know it has been a while, but I wanted to ensure that everything was covered here. In addition to what was shared above, check for any thermostat actions available in the Google Home app's Routines settings. Edit them if needed or remove them to avoid unexpected activation. Also, clear all scheduled temperatures you have created and restart the thermostat to refresh.
Let us know if you need more help.
