Nest thermostat not connecting to WiFi
DRock
Garrett pre-maturely closed this discussion. Folks are having a hard time keeping their thermostats connected to wifi. After resetting everything it appears to connect only to fail again and not connect. This is where I'm at now. No connection Garrett!! This is not solved by any means! You see I got the nest thermostat so I could monitor and adjust my thermostat when away from my house. Well when I'm across the country for work and you tell me just adjust it manually or reset it AGAIN. It is meaningless because I wouldn't need a WiFi connected thermostat is I was always home!! The point is, these things fail to connect and there is no solution!
Sabs
Going through the same issue.
juliantwilliams
I am having the same issue.  I bought the expensive model to be sure I could see how my condo in Florida is cooling.  It is not connected to wifi and I am not there to manually reset it.  This is not a great solution.  I have cameras and TiVo on the Wifi that are not having troubles.  Please help
juliantwilliams
Is this a function of the latest software update?
DRock
Same issues Julian. I even had a neighbor go in my house while I was away and reset the t-stat according to nest recommendations and one day later, no Wi-Fi connection again! The strange thing is it worked seemlessly for almost two years then this. Folks all over the country having the same exact problem and you can't tell me they can't tell what it is. Just starts happening? C'mon are we that gullible?
Like you I have other devices on that have stayed connected. Door bell cameras, locks, lamps, sprinkler system... My router is on a UPS and everything made it through a 12 hour power outage from the electric company. But then one day the t-stat stops connecting. C'mon nest engineers get off your keister's and fix this issue!! Julian you may be on to something with the software updates! Or they are just trying to force us to buy new models!!
