10-08-2023 10:52 AM
Nest thermostat went offline, will not reconnect, and cannot put in manual network information give me "no network found". I have tried all steps to fix, reset the router, factory reset the thermostat. Please advise
10-08-2023 10:55 AM
Same here today ! Is there a replacement program
10-11-2023 01:35 PM
Thanks for reaching out to the Google Nest community.
We're sorry for any trouble this may have caused you, @aduf1827. Let's see what's going on. When did the issue start to happen? And since you've already done a couple of troubleshooting steps, we need to check the recommended wifi settings. Some Wi-Fi network or router settings can affect the connectivity of our devices for security. What we normally suggest is the following:
Have a look at this article: Update Wi-Fi network and router settings for additional steps.
@Rrivman71, We have a replacement process, but we need to isolate the issue and perform troubleshooting steps to accurately identify the best resolution to fix the issue permanently. Please follow the steps I’ve provided above. Let me know what you’ve checked and done.
Renz
