Nest thermostat off but furnace fan won't stop running
Nina2023
Fan won't turn off unless I turn power off at the breaker. Nest thermostat is off but the fan has been running constantly for a couple of weeks. Before that it seemed to be working fine. I've seen lots of posts and questions about this but no solutions aside from uninstalling the best and going back to the old thermostat. I'm definitely leaning that way but hoping someone has an answer.
8 REPLIES 8
zoeuvre
Hi Nina2023,
Thanks for reaching out to us, and I'm sorry to hear about the situation. I want to check if you are still in need of any help. If so, remove the thermostat display from the base and wait about five minutes, then observe if the fan will continuously run or stop after removing the thermostat display.
Let us know how it goes.
Nina2023
Only turning the main power breaker off made it stop. I ended up disconnecting the nest and reinstalling our old thermostat and it all seems fine now so I'm guessing it's a problem with the nest.
zoeuvre
Thanks for getting back to us. Don't give up on us yet. We'd like to further check on this. Could you fill out this form and let me know once you're done?
Mike_721
I have the same problem fan in the middle of the night comes on for 15-30 seconds then turns off. The fan will stay off for 10 seconds and do that again. I can only get the fan to stop after I turn the power off to the furnace. Even with no power to the nest the fan still runs.
Mine was running constantly. I'm not sure if it started with sporadic running. Our power bill was getting crazy so I switched back to our old school thermostat and problem stopped. Good luck!
zoeuvre
@Nina2023, thanks for the additional information. We've received your form; thanks for filling it out. Please keep an eye on your email, as someone from our team will reach out to you to assist you more. If you have questions or concerns in the future, feel free to start a new thread, and we'll be happy to help.
@Mike_721, oh no! Don't give up on it yet. Were you able to try the same instructions I asked Nina2023 to follow? If not yet, kindly follow it and let us know how it goes.
Kind regards,
7sa
I have the fan issue and no help at all
zoeuvre
Hi 7sa,
Yikes! Sorry to hear that. Could you let us know more about the situation you're in with your fan so we can take a deeper look?
Kind regards,
