Nest thermostat showing no power error
JoeMoney
My nest thermostat has suddenly stopped working and is showing an E298 (no power) error. It has worked perfect for about a year but now for some reason has no power.
Houptee
What kind of heating/cooling system do you have?
Do you have and know how to use a multimeter to test for 24v AC voltage?
You should have 24-30v AC at the system if you test from R to C. If nothing then look for blown fuse on the board. Or transformer could be bad. Even the main board could be bad. Have to diagnose it using a multimeter is only way.
JoeMoney
Thanks Houptee
aatienza
Hey JoeMoney,
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, Houptee.
Archie
aatienza
Archie
aatienza
Hello there,
Archie
