01-03-2022 08:35 PM
I've recently noticed my best temperature is off. I have two other thermometers reading 1-2 degrees celcius less than the nest.
This wasn't an issue in previous years using it but has been in recent months. Potentially attributed to the 6.2-22 update.
I've reset the nest. I've restarted the nest and I get different results. It is 21 inside right now and after a reboot I got a reading of 25. Waited an hour and it went to 24 while it was still 21 in the house. I then disconnected the display from the base and replugged it and it showed 22.5.
Seeing as this is a 4 yr old unit I'm off warranty and honestly very upset that a 3-400 dollar investment fails to serve its primary purpose. I love the nest features but having a faulty sensor is a huge issue
There are a ton of users complaining about wrong temperature readings hoping Google reads these.... The latest update needs to be fixed or rolled back.
- Sunblock is off
- mounted in hallway away from rads/vents
- no heat coming from wall
