05-15-2022 06:00 AM
I have AWAY mode set to run ECO on my 2 nest non-learning thermostats. Randomly, the thermostats (usually one, but sometimes the other) will forget that it is in away mode and start running the HOME routine again, wasting fuel.
Here's what I have done so far:
- Presence is turned OFF
- AWAY is programmed to run ECO
- I am the ONLY user on my account
- I am using C-Wire from the furnace - Thermostats report these specs from my C wire:
- Vin: 37 V
- lin: 385
- PS: C-385
- I have tried deleting the thermostat, factory resetting it and re-adding it
- I have tried creating a new room and adding it there
Any suggestions? I have seen others complain with no responses... Does the AWAY feature simply not work and Google burying it?
05-15-2022 02:19 PM - edited 05-15-2022 02:21 PM
@imstarboard wrote:I have seen others complain with no responses... Does the AWAY feature simply not work and Google burying it?
I'm beginning to think the same as you...
My Home/Away routine is not working either - https://www.googlenestcommunity.com/t5/Nest-Thermostats/Home-Away-not-working/m-p/157886#M32578
No real help so far...
05-21-2022 08:38 AM
If you get anywhere with on email with Google, please ask them to look ay my post as well. Thanks!
