Nest thermostat wires for heat pump Blow Hot
NguoiViet41
Hi
I Need help on Nest Thermostat with heat pump system
after wires with Nest Thermostat i got hot air
Thankssssssss
my original wires
G  -  Green
C - Blue
R - Red
y  with jumper w1 - Yellow
W2 and E - White
O -  Orange
7 REPLIES 7
NguoiViet41
Houptee
Do not use any jumper wires on the Nest.
Try white to W2.
The OB is what changes the unit to Heat or A/C mode, so if it is wrong you have to change the function of OB wire.
Post pic of the Nest wiring.
NguoiViet41
old thermostart 2.pngI Try Both Still Blow hot
1-wires and setup O or  B No Go1-wires and setup O or B No Go2-wires and setup O or  B No Go2-wires and setup O or B No Go
Thanks for the assistance, @Houptee.
Great troubleshooting so far, @NguoiViet41. I appreciate that you've tried to find a fix. Let's find out more about what happened.
You can also give this steps a try in this article and let us know how it goes.
Houptee
Leave White wire disconnected and try the A/C mode.
If blows hot, change the O/B function in Nest settings until A/C works and blows cold.
Then once AC is working, now try turning on Heat to see what happens.
If you get heat with white wire still disconnected then the heat pump is working normal.
After the heat pump problem is solved you need to figure out is the White wire for emergency electric backup heat?
I appreciate your assistance, @Houptee.
@NguoiViet41, I'm checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns.
Hello NguoiViet41.
It has been a few days since the last reply, and I am going to lock the thread within 24 hours. If you have any questions, please feel free to create a new post.
