Nest thinks I have a heat pump; Does not recognize A/C
Seth1
Tried installing a Nest Learning Thermostat. I have a conventional furnace and conventional air conditioner, and the old thermostat was working fine. The Nest thermostat is saying I have a heat pump (I do not) and does not recognize that I do have an air conditioner.
Photos of the wiring from the old thermostat and the new Nest thermostat are included (note that the old  furnace was wired to "RH," and had a jumper wire from "RH" to "RC"). Any ideas what could be wrong?
roverton00
It looks like the blue wire (old terminal Y/O)should be plugged into the Y1 slot.
Seth1
Thanks, seems to have worked!
Thanks for posting in the Google Nest Community forum. It looks like you have come to a solution, so I'm going to lock this thread in 24 hours. If you have any other concerns or questions, please feel free to create a new thread.
I appreciate your input, @roverton00.
