Nest w connection has blue wire. Is that a concern? There is nothing plugged into the W
Jmatt
The W is connected to a blue wire and the C does not have anything connected to it.  There is a white wire however it is not connected to anything.
15 REPLIES 15
Jay_Utah
I would check your furnace out and see exactly what the blue wire is connected too and match that to your new one.
Houptee
Silver Product Expert
What kind of system do you have?
Is it a Heat Pump? Or a Nat gas furnace with AC?
You need to use one of the extra wires as a C wire and connect it to the furnace C terminal screw.
Jmatt
Thanks.  i don’t have a heat pump.  Natural gas furnace
Houptee
I suggest you go to the furnace and remove the cover.
Locate the terminal screws where the thermostat wires connect.
I would fix the strange wire colors they used and put the White wire on furnace W
Put the Blue wire on furnace C common (or if it is a Trane they call it B)
Then go back to the Nest and put
Red in RC
White in W1
Blue in C
G in G
Y in Y
Jmatt
Thanks Houptee.  I checked the white wire just hanging there and it has 12 mV power from the multimeter.  I’m wondering if it was installed without the white wire since the thermostat runs off battery- not sure why.  I’m still looking for the terminal near the furnace to confirm the wiring
Jmatt
Ok..good news.  I installed the nest using the following wires and it is working and responding.
W - Blue
Rc - red
G - green
Y - yellow
W - was left not connected.
should there be any concern with that setup?
Houptee
If it is getting good power when you do the power test and you get good readings it should be ok.
But connecting a C wire is always the best thing to do on these smart thermostats.
You just remove the front cover on the furnace and you will see the wires and screws in a row R Y G C W etc etc.
If you want to make it standardized to the normal color code you can move white to W and blue to C.
This video shows you how to test if you need to attach the C wire but i would do it anyway even if you have decent voltage.
https://youtu.be/GHkfnRp6Tj8
Jay_Utah
I figured that was the case. As king as you remember for another time. You could put a small label on the wires coming out of the wall
Something came out wrong on my last post. Just saying label the wires. Blue being where White should go. I believe white is for heat.
EdwardT
@Houptee and Jay_Utah, thanks for the help!
@Jmatt, I'm glad to hear that you were able to install your Nest Thermostat. Please observe it for now and let us know if anything comes up.
Edward
aatienza
Archie
aatienza
Hello there,
Archie
Jay_Utah
It does work : ) thanks for the help
I do need a backing plate do you know where I can get that?
aatienza
Hey Jay_Utah,
That's good to hear! You can fill out this form and let us know once you're done.
Archie
aatienza
Hey Jay_Utah,
We got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. Also, please be advised that this thread will be locked after 24 hours.
Archie
