Nest won’t connect to wifi
gdfrederick
I have a nest thermostat third generation. I had installed it several months back and it was working perfect. We have T-Mobile Internet and at first we were having trouble with it dropping off which would disconnect the Wi-Fi from the nest. It continue to work without Wi-Fi, but I am wanting to connect it again because it was really nice when I had it. Now I am unable to get it connected and it keeps saying that it is not connected to the Wi-Fi. It is not giving me any code. If anyone has a suggestion, I would love to hear it. Thank you so much.
lainix
make sure your attery has a charge it will lose wifi under 3.6 volts and takes a while to come back even after it charges back up.
go to technical settings and power to see your current voltage
Hey gdfrederick,
Thanks for the helpful reply lainix.
I wanted to follow up and see if I could be of any help. I found an article with some troubleshooting steps. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Hi gdfrederick,
