10-29-2021 06:27 AM
My nest had been working fine for over a year and all of a sudden it says no power to RV wire. I took wire out and re installed it and I turned on and off the circuit breaker. Nothing works
10-29-2021 07:45 AM
Same with mine. I had 4 notices that furnace only running for 15 min and shut off. HVAC guy here trying to correct furnace issue, but wonder if nest not working, might need replacement.
10-29-2021 09:46 AM
I have a similar problem happening right now. Installed Nest Learning on 1 April. Ran heat through May, then AC and Heat into June until we went to straight AC for summer. Multizone heating system (forced hot water) with two Nest E's on other zones. Testing heating system from Nest Learning on 6 Oct. Taco box just kept clicking. You will see other posts about this across the web. Call heating company for PM b/c I assumed the problem was with boiler. First thing tech said when he arrived was "you have a Nest thermostat, correct?". He performed the same troubleshoot you did (W to Rh wire - triggered heat). Notified Google and then sent me new baseplate (arrived last night and installed - no fix. Same exact issues). Contacted them again this morning and just went through 2 hours of painful chat troubleshooting with totally useless reps (Madison and then Enzo). If you get them, stop the chat, pull the Nest out of your house and get another brand. I'm done with having a teenager in their basement ask me if my house is powered and calling it support/troubleshooting.
12-16-2021 12:50 PM
Hey all,
Sorry for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
12-21-2021 10:53 AM
Hey all,
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
12-22-2021 10:47 AM
Hey all,
It has been a few days since the last reply, and I am going to lock the thread at this time. If you have any questions, please feel free to create a new post.
