02-16-2022 05:04 PM
Have had the best for a year or two. No problems. Now will only heat not cool. Any ideas I try every single step like changing O to B and B to O and Rh to Rc and nothing .
02-22-2022 03:27 PM
Hey Nelly885,
Thank you for reaching out and we're sorry to hear about what's happening.
Since you've tried changing the O/B orientation and still getting the same thing, we could try to check the wire from the terminal. Make sure it is properly inserted, to be sure try to re-strip the wire to expose new copper.
Also, check the filters and drip pans as they also become clogged overtime.
Let us know how it goes by replying to this thread.
Ryan
04-05-2022 06:40 AM
I just want to add Cooling to my Thermostat.
06-12-2022 03:26 PM
Hope this helps!
Kind regards,
Ryan
