Phone is not showing room temperature & water
JonBoy1943
Lost the ability to see room temperature and water on phone. Oh thermostat went through all instruction and when it is supposed to show code it tells me: “ thermostat is connected to an account “
this is no help.
is the code 4 letters & 2 numbers on the back of the thermostat?
if so how do I use them
Jeremyg
Hi @JonBoy1943!
Thanks for reaching out to the community. I am sorry that your Nest thermostat is not showing you the room temperature and water, but no need to worry; help is here. I need to know a few things about your thermostat in order to provide you with a better resolution.
  • What Nest thermostat model do you have? For your reference, you can check out this article on how to tell which Nest thermostat you have.
  • Are you trying to add the Nest thermostat on the Nest app or the Google Home app?
  • When did the issue first occur?
  • When was the thermostat installed?
  • What is the make and model of your HVAC equipment?
  • Do you see a blinking LED light? If so, is it red or green?
I'll be waiting for your response; any additional details you can provide will be helpful.
Jeremy.
