Problems with Nest thermostat
Nodarsejg
Since my Nest thermostat finished the process of analyzing my habits to self-adjust; The air conditioning cools during the day and the fan only works at night.
AxelD
Hi Nodarsejg,
Thanks for posting in the community! Sorry to hear that the Auto-Learning in your Nest Thermostat isn't working as you wanted. No worries, help is here! My recommendation would be Clear the existing schedule. Here you have the steps to do it:
  1. On your thermostat, select Settings >  Reset > Schedule.
  2. Depending on which Nest thermostat you have, select either Reset or Clear.
Note: If you have a Nest Thermostat E, you can select Basic to clear your existing schedule and replace it with the default basic schedule.
Let me know how it goes.
Axel.
