07-17-2023 11:13 PM
Old system Honeywell, works great. Installing a new Nest.
No Heat Pump/Conventional AC
Honeywell thermostat (old)
No C
White, Yellow, Red and Green wires hook all color coded.
Jumper from red to RC
Nest Learning Thermostat (new)
No C
No jumper from red to RC (read it is not needed.)
Turn it on to cold setting and in about 15 minutes, temperature raised 10 degrees.
Please Help hot day in AZ.
Original Honeywell, can be put back and works fine.
rightstuffproduction at gmail dot com
Subject Thermostat
07-20-2023 04:40 PM
Who ever wrote to me by email. I tried to reply to you but error says your email does not exist.
REPLY ON THIS FORUM ONLY.
07-21-2023 10:45 PM
Hello RightStuff
Thanks for reaching out here in the Community. To confirm, how many Nest Thermostats do you have? Do you see any error messages? Please go to settings> Technical Info> Power and get all the information there and post it here. Make sure that all wires are connected properly to their terminals. Make sure there's no exposed wires. Let us know how it goes.
07-24-2023 11:35 PM
Hi RightStuff,
I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
07-25-2023 01:43 PM
Nobody has provided a solution to problem that I am having.
Pic of old hook up. Note: jumper from R to Rc. Did not do this to new thermostat.
07-25-2023 06:52 PM
Hi RightStuff,
Thanks for posting here in the Community. Based on the photos of the wires from your old thermostat, it seems it is just a conventional heating and cooling system, but as you mention, it blows hot air instead of cool air. Have you tried connecting the white wire to the O/B terminal in the Nest thermostat base?
Thanks for the help, @Emerson.
Edmond
07-28-2023 10:44 PM
Hello everybody,
@RightStuff, we wanted to follow up and see if you are still in need of any help. Please let us know if you are still having any concerns or questions from here, as we would be happy to take a closer look and assist you further.
I appreciate the help, Edmond.
07-31-2023 07:32 PM
Edmond
