02-23-2025 09:18 AM
I want to set both my Nests at 45 degrees while we are away. When on ECO I cannot get them to go below 50. If I turn ECO off I have to adjust each day. For two thermostats that’s 14 adjustments. What is an easy way to have the thermostats set and hold a temp.
Chris
02-26-2025 04:30 PM
Hi @Csnow,
Thank you for posting in the community. I understand you want to know how to set up a temp hold when you are away. I'm happy to assist you.
Based on what you mentioned, I recommend that you first set up the Home/Away Assist feature. With Home/Away Assist, all of your Nest products can automatically change their behavior as people come and go. For example, it can turn on your Nest Cam to help you keep an eye on things when you leave home, and turn it off when you’re home and don’t need it.
To learn more about Home/Away Assist, you can find all the necessary information in the article "Change Home/Away Assist setting."
After setting up Home/Away Assist, you only need to adjust the Eco temperature for heating or cooling, as described in the article "Learn about Eco Temperatures, Auto Eco and how to change settings," depending on your Nest Thermostat model.
Please keep me posted.
Anders
02-26-2025 04:30 PM
Hi @Csnow,
Anders
