Setting low temperature alerts on a nest
ColdinNH
Hi during the night furnace failed. The temp was set to 62F. Is it possible to send a notification to the iPhone when temp is 60F?
MelbaDT
Hi DocOnTech,
Sorry to hear about what happened and for the delay.
Quick question — what country are you in? If you are in an one of the eligible regions in the US and Canada, we have Google Nest HVAC monitoring feature that can help you identify potential issues with your HVAC system. If a potential issue is detected, we’ll send you an alert via email or a Google Home app notification. Check this out for more information: https://bit.ly/3sUj8lP
Melba
MelbaDT
Just checking back in if you still need help with your Nest thermostat.
Melba
MelbaDT
Since it's been since this thread was last updated, we'll be locking it if we won't hear back from you again within a day. Should that happen, feel free to create a new one should you have more questions or have other concerns in the future.
Melba
ColdinNH
Hi
can the alerts of low temperature be set to a higher temperature ie 60? Currently I can only set between 35 and 45.
