Setup Nest Thermostat two-stage for Electric Wall Heaters
cabinguy
I have a seasonal cabin that currently has two 240 volt wall heaters.  each is on a separate circuit and I am working on a design with Aube relays that allow connection to 24volt thermostat systems like Nest.  I would like to use the heaters as a two stage system.  I have questions on the C Wire and Rh wire connections when a relay is used for each wall heater.
Please see the link below for details.
https://drive.google.com/file/d/1JnToXOYT0CTJBbW7jiAWuQfqDQ_Ws4g2/view?usp=sharing
Jeremyg
Hi @cabinguy
Thanks for reaching out to the community. Thank you for your interest in setting up the Nest thermostat two-stage for electric wall heaters, but no need to worry; help is here. I need to know a few things about your thermostat in order to provide you with a better resolution.
  • What Nest thermostat model do you have? For your reference, you can check out this article on how to tell which Nest thermostat you have.
  • When was the thermostat installed?
  • What is the make and model of your HVAC equipment?
  • How many wires are there?
I'll be waiting for your response; any additional details you can provide will be helpful.
Jeremy.
