Should I reduce flow temperature?
Wennett
I've recently turned down the flow temperature on our gas combi boiler - down to between 50 and 55 degrees celsius (am experimenting with the exact amount).
The result is that it now takes longer for the system to heat up - e.g. to get a thermostat to 18 degrees may take 1.5 hours vs 50 minutes previously.
My question is whether this uses less energy and heating - is it better to have a lower flow temperature on in the boiler, but meaning the nest is on for longer, or a higher flow temperature which means nest is on for less as it gets to the scheduled temperature quicker?
zoeuvre
Hi Wennett,
Thanks for reaching out to us. Lowering the flow temperature on your gas combi boiler can have an impact on the heating performance and energy consumption of your system. Lowering the flow temperature in your radiators can improve energy efficiency by reducing heat loss and optimizing boiler performance. Modern condensing boilers are designed to operate more efficiently at lower flow temperatures, making lowering the flow temperature a trade-off between energy efficiency and comfort. Lowering the heat-up time may also increase the time it takes for the system to reach the desired temperature, but if the longer heat-up time is acceptable and you still achieve a comfortable temperature within a reasonable timeframe, it may be more energy-efficient to operate at lower flow temperatures.
Occupancy and scheduling preferences can also be considered when adjusting the schedule to account for longer heat-up time. A consistent daily routine can help ensure the desired temperature is reached without wasting energy when not present. Comfort preferences vary, so if longer heat-up time negatively impacts your comfort or causes inconvenience, consider a higher flow temperature for quicker heating. Finding the right balance between energy efficiency and comfort depends on your specific circumstances, so experimentation with different flow temperatures can help.
Let us know if that helps.
