11-14-2023 08:13 AM - last edited on 11-23-2023 09:33 AM by zoeuvre
Re: New system 11/3/2023, Goodman 2 Ton 14 Seer 60,000 Btu 81% Afue Gas Package Air Conditioner GPG1424060M41,
New Nest Ver 3 Thermostat
Reference: All was working Excellent until the Temperature dropped below 32 degrees.
Problem: Using Gas Heat Nest says (while Red) 1 hour to heat to 73 degrees (28 Degrees outside this morning). I waited more than 3 hours and NOTHING but, the temperature seems to be tolerable at 67 degrees.
Note: Same problem 1.5 Hours for Heating/Cooling and NOTHING.
Fan works (Burrrrrrr) 😞
Moderator edit: Subject updated for clarity and findability.
11-16-2023 01:40 PM - edited 11-16-2023 01:41 PM
!RESOLVED! 11-16-2023
Ok, I spent a lot of time AND money to get this QUITTING IN THE COLDEST OF WEATHER resolved.
Also, the solution came to Me with no help from anyone here on the NEST forums. Not one peep.
Therefore The solution is not something I wish to disclose, as such would not be fair to Me, the Manufacture of the Heating products and the people who service them all.
Good luck everyone!
