T-stat thinks I have a heat pump and I don’t. It activates a/c when I set it to heat.
ScottFleck
Installed a complete system in the summer and all works.
I switched to a Nest since and a/c works good.
I tuned on heat for the first time with Nest and it turns on the a/c instead of the heat.
I can only get heat in emergency heat mode.
The Nest thermostat isn't wired correctly.
Post a picture of the original thermostat wiring if you have it and a picture of how you have the Nest wired
Good morning, (at least here). I don’t have a picture of the old one. How do I send a picture of the new one. I don’t see where to attach.
white wire to W
red to R
green to G
yellow to Y
blue to C
ScottFleck
I received an email saying you responded. No response.
ScottFleck
I received an email that you responded but there is no response.
ScottFleck
