12-23-2022 09:11 AM
I have a nest (not migrated) gen 2 thermostat. It has been working flawlessly for 5 years. I also had 3 temperature sensors connected to this thermostat for 3+ years. Just recently the temperature sensor I used to control the temperature started saying it had an unreliable connection to the thermostat. I noticed the heat or cooling was running past the set temperature as well. I tested the connection through the app and it tested good. I changed the battery and removed and reset the sensor. A week later same thing. I bought a brand new sensor, and moved that problematic sensor to a different room. The new sensor is now also showing as having an unreliable connection to the thermostat, while the problematic one I moved is perfect.
It has been in the same location for years, and is not the furthest from the thermostat.
The only thing we have changed is installing a new wifi lightbulb on the porch on the opposite side of the house, not in direct line of sight of the thermostat. None of the other rooms are having any issues with their sensors.
Anyone have any idea what could be causing this one room to all of a sudden have trouble connecting?
12-24-2022 06:31 AM
Sorry, I have a 3rd generation, not 2nd generation
01-05-2023 11:37 AM
Hello Robb79,
I'm sorry for the trouble this may have caused you, and I appreciate all the steps you've taken. I'd love to know more about this.
Since it has been isolated with a new sensor and by moving the first sensor to a different room. Network interference may have caused this issue. To isolate:
Also, please give these steps a try:
01-07-2023 07:51 AM
Mark,
Thanks for your response. Here is my reply.
Restarted router and thermostat, might be a week before I see if the error recurs. Battery level was 3.93V. I will update if removing the bulb has worked, It may take a week to be sure.
01-08-2023 12:29 PM
Thank you for informing me of this, and I look forward to hearing the outcome of your investigation. Please keep us posted on how it goes.
01-11-2023 02:55 PM
Hi Robb79,
I'm checking back in — how's it going? Still need our help? Please let us know so we can assist you right away.
01-11-2023 04:38 PM
The lightbulb was not the culprit. I am testing a few more devices.
1. A wireless access point.
2. A USB wall plug we installed recently in the same room as the sensor.
I hope to narrow it down to one of those. I will report back in a few days.
02-08-2023 02:52 PM
Hi Robb79,
I saw your post and wanted to chime in. I'm sorry for the delay. I just want to confirm if you still need some assistance as I'll be willing to assist you from here.
@Markjosephp I appreciate your help.
02-13-2023 07:47 PM
I appreciate the help, everyone.
Archie
02-15-2023 03:50 PM
Hello there,
Archie
