Temperature keeps going lower than what I program
Raremy
I set the temp to 74 degrees and it will lower to 69 degrees.  How is this happening I do have it password locked.
MrVacca
Sorry to hear about that @Raremy. I suggest double checking to see if you have any schedules set up and then deleting them. You also might want to check to see if you have eco mode set up.
Keep us posted, thanks!
janthadeus
I just wanted to jump in real fast to see if you saw MrVacca's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks for your help here, MrVacca.
janthadeus
Hi Raremy,
Checking back in should you still have further questions here. Let us know by replying to this thread.
EdwardT
Hi Raremy,
Edward
