01-16-2023 12:07 AM
Hello- I bought a temperature sensor to connect to my learning thermostat with the goal of testing/verifying that it is compatible and to test its use cases. I have my thermostat linked to Alexa so that I can adjust or check temperatures right from my fire tv cube. I was completely surprised to find out that while I can check the temperature in the hallway where my thermostat is, I can NOT check the temperature of my new sensor in my daughters room with Alexa. This is extremely unfortunate because this feature was one of the MAIN reasons I was going to put a sensor in every room of my house. To be able to verify select area’s temperature before any family members complain, or setting up some automation/notification if certain rooms get too hot or cold. PLEASE consider these sensors compatibility with the Alexa’s Google Nest skill so we have some voice commands. I am probably going to look at Amazon temperature sensors as an alternative now.
01-20-2023 02:42 PM
Hey Dudedilli,
We appreciate your interest however; we don't have any news to share about compatibility for your Nest Temperature Sensor with Alexa. We're always looking for ways to improve and we'll take it as feedback.
I also suggest that you send feedback by following this link. Let me know if you have other questions or concerns, otherwise I’ll be locking this thread after 24 hours.
01-24-2023 04:39 PM
Hi Dudedilli,
Edward
01-25-2023 05:48 PM
Hi Dudedilli,
Edward
