06-22-2024 03:33 PM
I'm trying to unlock the nest thermostat. It has a code which I'm entering but it is not working. I need it reset to factory settings.
06-23-2024 08:23 AM
If your thermostat is still connected to Wi-Fi and you can see it in the Nest app or Home app, you can unlock and reset the PIN using the app:
Lock and unlock your Nest thermostat - Google Nest Help
If you can't control it using the app anymore, you'll need to reset it using a computer.
If the Nest drive is successfully showing up on your computer, can you see a technicalinfo.PLIST file? If you get this far let me know and I'll ask a community specialist to assist with next steps, as these can't be shared publicly in the community.
