Thermostat changing settings on its own
SArthur
I have a Nest in my 2nd home. For some reason, I looked at the a/c usage today & noticed that it had changed from Eco to sleep mode last night and ran at 67° for about 19 hours. No one is there and it has been set on Eco mode for months. What made it switch to sleep mode & why did it not end when the sleep mode ends at 8am?  How do I prevent this from happening again??  I don’t want to have to check it every day!!!
luciaaa
Hi, @SArthur ,
Thank you so much for reaching out to the community. I'm truly sorry your schedule isn't working properly. We'll definitely work to find a solution.
To help me understand the issue better, I have a question:
  • When did the temperature start to change unexpectedly?
In the meantime, I recommend you to follow the next steps:
  • Reset schedule.
    • Open the Google home app.
    • Tap Settings > Schedules
    • On the upper-right corner of the app, tap the three dots icon. Select Clear weekly schedule.
  • Create a new schedule.
    • Open the Google Home app.
    • Tap Settings > Schedules.
    • Tap Add to create a new schedule.
Let me know how it goes.
Ana.
