Thermostat does not connect to the heat link
OLudolf
My thermostat is connecting the my heat link. II have tried resetting the heat link and looking at the settings on my thermostat and I still can't connect them. I had this exact same problem around two years ago and somebody from Google came to fix. Help me.
humbertogarcia
Hi OLudolf,
Thanks for posting in the community! I understand you're experiencing a persistent connection issue between your Nest thermostat and the Heat Link, similar to one you had two years ago. I appreciate your troubleshooting efforts. No worries, I'm here to assist you with this!
To help me guide you efficiently towards a swift resolution, I’d like to ask you some questions:
  • What’s the model of the Nest thermostat that you have?
  • What are the exact light colors and patterns currently showing on both your Heat Link and your thermostat displays?
  • Do you see any specific error messages or codes on your thermostat's screen?
  • When you performed the Heat Link reset, could you describe the precise steps you took?
  • Have there been any recent power outages, internet disruptions, or changes to your home Wi-Fi network?
Your insights will be incredibly helpful in guiding me.
Humberto
