01-04-2022 09:31 AM
I have two Nest thermostats. One will not trigger the heat to turn on. When it hits the temperature, there thermostat activates the fan, but no heat. The other thermostat works fine. If I switch thermostat locations, I have the same problem with the thermostat while the "good" thermostat continues to work properly regardless of location.
