05-17-2024 11:24 AM
After 3 years or so of use, almost 4 years, one of my many Google Nest Learning Thermostats is suddenly showing the message "Thermostat doesn’t have enough power for Wi-Fi". My guess is that the lithium ion battery is no longer charging sufficiently. If the battery is toast, do I need to replace the battery? Or the thermostat?
Thank you.
05-20-2024 04:04 PM
Hello JFXFJR,
Thanks for reaching out to the community. I'm so happy to help you with your thermostat situation.
Let me inform you that this thermostat model has a non-replaceable battery. Unfortunately, the entire thermostat will need to be replaced.
Tell us if you need assistance; we are happy to help you.
Douglas.
