Thermostat problems issues
Stiopa1972
Hi, I just change my Wi-Fi net work reconnect my nest thermostat to a new Wi-Fi and sounds like thermostat doesn’t sending a signal to my furnace. Anybody can help
And your description, this one does not have anything to do with the other. That is the say changing the Wi-Fi should not have changed anything to do with the heating system.  Check the nest equipment setup to see if the W terminal wire is still connected.
The AC Cooling Wizard
zoeuvre
Hi Stiopa1972,
Thanks for reaching out to us, and I'm sorry to hear about the situation. Let's sort this out.
A few questions: What type of Nest Thermostat do you have? Also, do you see any error code on your Nest Thermostat display? To check for it, go to Settings, then look for Equipment. Also, please help us with the power reading of your Nest Thermostat.
  1. To open the Quick View menu, press the thermostat’s ring.
  2. Choose Settings.
  3. Turn the ring to highlight Technical Info then press the ring to select it.
  4. Select Power.
    • Battery
    • VOC
    • VIN
    • IIN
Thanks for your help, @CoolingWizard
Hey Stiopa1972,
Hi Stiopa1972,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
