11-01-2023 03:44 PM
This may be a normal function of the thermostat.
I have the heat set on 69. Currently the thermostat is reading 68. The heat is not turning on.
If I “click” the thermostat once to the right; it goes on no problem, so the heat itself works.
I’m just more or less confused as to why it’s not turning on to actually hit the desired temp?
Over the summer with the AC didn’t have this issue at all.
the machine is a heat pump. Is this heat pump related?
thanks much.
11-05-2023 08:27 AM
Hi avc_dc,
Oh no! I'm sorry to hear that your Nest Thermostat is not heating to your desired temperature. Let me take a look at this for you. A few questions:
Keep us posted.
11-05-2023 05:57 PM
I was able to figure it out! Thank you!
11-06-2023 11:10 AM
Awesome! I'm glad that everything has been sorted out. If you have questions or concerns in the future, feel free to start a new thread, and we'll be happy to help.
12-10-2023 02:25 AM
What did you do? Mine is doing the same.
12-10-2023 09:08 AM
Nothing at all, actually. I realized it’s a normal function of this thermostat (and other) where it’ll start a tad lower and go a tad higher so the unit isn’t on nonstop.
12-10-2023 09:09 AM
For example, mine set at 69 - it’ll go on at 68 and turn off at 70.
if it went down to 67 and still didn’t turn on, I’d be worried.
12-10-2023 11:34 AM
Thank you so much! I just now got one so I’m learning.
12-14-2023 08:25 AM
I just want to check if you still have questions in mind, as I'll be willing to help.
I appreciate your input, @avc_dc.
12-19-2023 02:32 PM
I just installed my nest thermostat and I have the heat set on 69. Currently the thermostat is reading 67 and The heat is not turning on. I can manually raise the temp to 70 and it will go on but only for a short while and the thermostat still says 67.
I don’t know why it’s not turning on to resch the desired temp if the inside thermostat on my app says 67. Is there something I didn’t set up correctly?
12-19-2023 02:46 PM
It’s correctly setup I’m sure.
Since there is that band of 1-1.5 degrees you have it set on 69, and the 67 is showing, it could actually be 67.7 and it hasn’t quite hit the band yet.
if it drops to 66 inside, then I’d say you have a problem. But not yet.
12-19-2023 04:15 PM
Well example, we had it set on 70 and woke up at 1:30 am this morning freezing. Looked at nest and it showed it was 61 in our house. Hours and hours later it finally got back up to 70
12-19-2023 04:18 PM
Was the heat on when it was 61? Do you have a heat pump? How cold was it outside?
it got back up to 70 tells me the thermostat works but maybe it’s the unit? A lot of factors at play.
12-19-2023 05:33 PM
I turned the heat to 70 and it came up a couple degrees before it shut off, but the thermostat never reached 70. It’s a heat pump but the system is only 6 years old.
my Google Home app says the temp inside is even lower than the nest thermostat says.
Its about 40 degrees outside.
11-21-2023 02:03 PM
Actually I am having this same problem: The heat is set to 21, and when it drops, I have to manually turn it to the right and back to get it to turn on heat. Help anyone?? Thanks!
11-21-2023 02:44 PM
What ended up being my issue (I’m the one who opened the ticket) was not realizing there’s a deadband of about 1 degree or so.
For my example with heat set to 69 but it was on 68, I was always assuming it would “click on” right away. Once it hit a “lower 68” the heat would kick on.
someone on here can probably explain it better. Haha
11-24-2023 02:57 PM
@Clara55225, thanks for reaching out to us, and I'm sorry to hear that you're experiencing the same with your thermostat. I want to check if you managed to see the fix from avc_dc. Please let us know if you still have questions or concerns, as we'll be willing to assist you more.
Thanks for your help, @avc_dc.
12-15-2023 01:51 PM
We have a gas furnace. If we have the heat set on 70 during the warmer part of the day it stays around 69 but when the temps drop at night it becomes 60 and 61 degrees in our house and won't warm up. It will tell us it will reach 70 in around 1 hour but never does so through the night and early morning we freeze because we have no heat. The furnace continues to run during this time.
