Thermostat won’t work
Whatthehell
After a power outage my thermostat will not come on and thus no heat. I’ve read so many articles….no help.
I need advice and instructions. It’s freezing here!
fortean
Need more input. Need more input.
E.g. what type of thermostat do you have? If it is the EU type (with heatlink) press the big button right in the middle of your heatlink, and the heater should start heating.
Unless, of course, you have some diagnostic code on your heater. For example, say your water pressure (pressure on the radiators) is below its limit. Typically, when you reset the boiler (what is what happens after a power outage) the heater will detect this and refuse to start. And then, the poor Nest (or the heatlink) can yell at your heater all it wants, but to no avail..
Thanks for the helpful reply fortean.
I wanted to follow up and see if I could be of any help. Are you getting any error codes on the device? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
aatienza
I appreciate the help, Jake.
Archie
aatienza
Hello there,
Archie
